Remotly provides several default layouts, but to play a PC game comfortably on Android you usually create a custom one with controls for all the actions you use.
Creating a new layout
Start Remotly, connect to your PC and run the game. Open the menu and select Game Control Layouts.
The manager lists layouts on the left with a preview on the right. Review the defaults and pick the closest match.
Select Duplicate to create a copy of the chosen default, enter a name (we recommend the game title) and confirm.
Basic editing
Select your new layout and tap Edit.
- Move a control by holding it and dragging it across the screen; controls cannot overlap.
- Resize a control by selecting it and using the Size slider on the left panel.
- Change mouse or keyboard actions by selecting a control and tapping the event (OnPress, OnUp, …) on the left panel.
- For buttons you can also pick a color and an icon.
Tap Accept to save your changes.
Adding and removing controls
Use the Add button at the top and select a control type; the new control appears in the center of the screen. To remove a control, select it and tap Remove.
Importing and exporting layouts
All layouts can be exported to the cloud and are assigned to your account, so you can use them on other devices. Hold a layout name to open the options menu and choose Import or Export.
Applying a layout to a game
Use the Apply button. Remotly remembers the applied layout for every PC game and loads it automatically next time.
