With Remotly you can run and play any PC game on your Android device in HD or 4K quality.
Run a PC game from your Android device
Open the Remotly app on your device and connect to your PC (see Connecting a mobile device to your PC). In Desktop control mode move the mouse cursor over the game icon and double‑tap to launch it.
Game Control mode and layouts
Remotly automatically switches to Game Control mode when a fullscreen PC game is detected and displays a game control layout. If it does not switch automatically, open the menu and choose Switch to Game Control.
Layouts consist of buttons, touchpads, sliders and other controls mapped to keyboard and mouse actions:
- Open Menu button (top right) opens the Remotly menu
- Open Keyboard button (top right) shows a keyboard for text, shortcuts and navigation
- Mouse control button (top left) provides a fullscreen touchpad
- Quick edit mode button (top left) lets you move game controls quickly
Customize game control layouts
Remotly ships with default layouts; for the best experience adjust one for your game. Open the menu and select Game Control Layouts manager.
Find the layout that suits your game best and hold it to open the options menu.
Duplicate the layout, name it after your game, select it and tap Edit.
In the editor you can move buttons, resize them, assign new key or mouse events, and add or remove controls. See How to edit game control layouts for details, then play and fine‑tune as needed.
