This tutorial requires Remotly installed on your PC and your mobile device and an active Remotly account.
Set up Remotly on the PC
Run Remotly on your PC and log in with your account name and password.
A successful login is confirmed with a popup.
Set up the mobile app
Make sure Remotly on the PC is running and logged in. Run the Remotly app on your mobile device and log in with the same account.
After logging in you will see the list of PCs available for connection.
Connecting to the PC
Tap your PC — the app starts connecting and shows a connection popup.
After a successful connection your PC desktop appears on the mobile screen.
Now you can control your PC and play PC games on your smartphone or tablet.
Device authorization
Every mobile device connecting to your PC for the first time must be authorized on the PC. Confirm the popup on the PC once.
