Troubleshooting
Low signal or bandwidth troubleshooting — PC
What the low signal warning means on PC and how to improve connection quality.
High‑quality remote access needs sufficient network signal and bandwidth on both ends.
Low signal or bandwidth warnings
When Remotly on your PC detects a problem it shows the Low signal or bandwidth warning icon.
Warning icon
Low signal troubleshooting
Make sure both the remote and the local device have good signal quality. On Wi‑Fi, move closer to the access point or switch to a wired connection.
Low bandwidth troubleshooting
  • Close all bandwidth‑consuming software and devices in your network (torrents, downloads, streaming).
  • Switch to 5 GHz or 6 GHz Wi‑Fi or to Ethernet.
  • Lower the resolution, frame rate or maximum bitrate in the Quality settings of the Remotly window.
